Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Turn the phone so its back is facing you.
Press the release button on the back cover, while simultaneously pulling the cover down.
Remove the back cover.
Pinch the sides of the bottom of the battery and pull upward.
Orient the phone so its back is facing you.
Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
Инструмент, используемый на этом этапе:Spudger$3.99-
Lodge a spudger in between the front panel and the main frame of the phone.
Using a good amount of torque, pry the front panel from the phone.
Place the phone on its back.
Insert the spudger at the bottom of the phone, between the phone's frame and the circuit board.
Remove the circuit board from the frame.
Bend the screen clamps outward so they are no longer underneath the circuit board.
Pull the screen encasing away from the circuit board.
Unplug the screen-to-phone interface.
Remove the screen from its encasing by pushing it out.
Еще один человек закончил это руководство.
