Motorola C261 Button Circuit Board Replacement
Выберете то, что вам нужно
  1. Motorola C261 Button Circuit Board Replacement, Place Phone: шаг 1, изображение 1 из 1
    • Place the phone with the screen facedown on a flat surface.
  2. Motorola C261 Button Circuit Board Replacement, Latch and Back Cover: шаг 2, изображение 1 из 2 Motorola C261 Button Circuit Board Replacement, Latch and Back Cover: шаг 2, изображение 2 из 2
    • Pinch the latch upwards towards the top of the phone.
    • Lift the back cover of the phone.
    • There are tabs on the bottom end of the battery cover that the cover pivots about.
  3. Motorola C261 Button Circuit Board Replacement, Remove Battery: шаг 3, изображение 1 из 2 Motorola C261 Button Circuit Board Replacement, Remove Battery: шаг 3, изображение 2 из 2
    • Remove the battery by pressing on the edge of the battery from the top of the phone towards the bottom and lifting up.
  4. Motorola C261 Button Circuit Board Replacement, Screws in Rear Housing: шаг 4, изображение 1 из 1
    • Remove the four 8.5 mm screws from under the battery cover with a T4 Torx screwdriver.
    • Remove the two 8.5 mm screws from the top of the phone with a T4 Torx screwdriver.
  5. Motorola C261 Button Circuit Board Replacement, Rear Housing: шаг 5, изображение 1 из 2 Motorola C261 Button Circuit Board Replacement, Rear Housing: шаг 5, изображение 2 из 2
    • Using the plastic pry tool remove the rear housing from the rest of the phone. You may have to pry around all edges of the phone, not just the edge shown.
    • When you remove the rear housing, the rubber cover for the headphone jack/charge port may fall out. If not, remove it.
  6. Motorola C261 Button Circuit Board Replacement, Spacers: шаг 6, изображение 1 из 2 Motorola C261 Button Circuit Board Replacement, Spacers: шаг 6, изображение 2 из 2
    • Remove the small black circular rubber spacer.
    • Remove the white rubber spacer.
    • These pieces are small and easy to lose, especially the black one. Set them somewhere safe!
  7. Motorola C261 Button Circuit Board Replacement, Motherboard and Front Housing: шаг 7, изображение 1 из 2 Motorola C261 Button Circuit Board Replacement, Motherboard and Front Housing: шаг 7, изображение 2 из 2
    • Gently remove the motherboard assembly from the front housing.
    • Now, the front housing is free to be replaced, as well as the cosmetic keypad.
  8. Motorola C261 Button Circuit Board Replacement, Clips: шаг 8, изображение 1 из 2 Motorola C261 Button Circuit Board Replacement, Clips: шаг 8, изображение 2 из 2
    • Remove the 2 clips from the sides of the phone, just below the screen with the pry tool.
  9. Motorola C261 Button Circuit Board Replacement, Button Circuit Board: шаг 9, изображение 1 из 2 Motorola C261 Button Circuit Board Replacement, Button Circuit Board: шаг 9, изображение 2 из 2
    • The circuit board for the buttons is now free to be removed and replaced.
Заключение
Jason
Участник с: 10/23/14
305 Репутация
Автор 3 руководств
Команда
Michigan Tech, Team 1-6, Lauer Fall 2014 Участник Michigan Tech, Team 1-6, Lauer Fall 2014
MTU-LAUER-F14S1G6
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 112
