Выберете то, что вам нужно
Pinch the latch upwards towards the top of the phone.
Lift the back cover of the phone.
Remove the battery by pressing on the edge of the battery from the top of the phone towards the bottom and lifting up.
Remove the 2 clips from the sides of the phone, just below the screen with the pry tool.
The circuit board for the buttons is now free to be removed and replaced.
Pry under the display screen, around each edge until it comes loose from the circuit board.
Gently remove the plastic and metal framework of the phone by picking it up.
The front speaker should be contained in the framework that you just removed. Remove the speaker by lifting it out.
Use a tool that isn't sharp to poke it out should the first method prove too difficult.
