Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This repair guide describes how to remove the screen of the Motorola C290.
Запчасти
Детали не указаны.
  1. Flip open your Motorola C290. Remove rubber stoppers located around main screen using a push pin. This reveals four screws.
    • Flip open your Motorola C290.
    • Remove rubber stoppers located around main screen using a push pin.
    • This reveals four screws.
    • Use a Torx T6 Screwdriver to unscrew the four screws.
  2. Use a plastic opening tool to pry open a gap between the top cover and the face of the phone. Slide the plastic opening tool along gap and pry open case.
    • Use a plastic opening tool to pry open a gap between the top cover and the face of the phone.
    • Slide the plastic opening tool along gap and pry open case.
    • Remove top cover.
  3. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  4. Unclip circuit attachments located on back of screen circuit board using a Spudger. Unclip circuit attachments located on back of screen circuit board using a Spudger.
    • Unclip circuit attachments located on back of screen circuit board using a Spudger.
  5. Insert the plastic opening tool between the metal screen components and the plastic frame at the corners. Firmly pry the screen components from the frame with a twisting motion You will need to apply a good amount of force as you pry, twisting in a right-to-left motion.
    • Insert the plastic opening tool between the metal screen components and the plastic frame at the corners.
    • Firmly pry the screen components from the frame with a twisting motion
    • You will need to apply a good amount of force as you pry, twisting in a right-to-left motion.
    • Completely remove screen components from frame.
Заключение
Angelo Ballungay
Участник с: 15.04.2010
76 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 24-28, Regan Spring 2010 Участник Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,625
