Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use your finger to press the button and free the device rear case.
slide the black button to free the battery so you can grab it with your other hand.
You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
Use your thumb to gently peel the keyboard off the front case.
Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part.
The last thing you need to doto access the Logic Board is to separate the Keyboard/Screen block just taking apart with your fingers.
Use a metal spudger togently free the screen/ear speaker metal case.
Use a plastic spudger to pell off the two cables on the back side of the screen.
The upper speaker is kept in place by a metal plate.
Use a metal spudger to free the 3 clips on the back side
Insert your metal spudger to remove the metal plate and free the upper speaker.
Here you can see all the parts composing the Motorola C350.
