Введение
Use this guide to replace the keypad guard on the front of the phone.
Инструменты
Запчасти
Детали не указаны.
Remove the battery by sliding it down the rails to which it is connected.
Find a flat head or Phillips head screwdriver.
Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
Use the screwdriver to push the rods towards each other until they click out of their locked position.
Slide off the antenna guard.
Locate the four clips on the exterior of the rear casing.
Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
Remove the old key guard from the rear casing by taking it out of its position.
Locate the circular extensions protruding from the top of your new key guard.
Push inwards on the small tabs on the side of the protrusions until they are no longer sticking out.
Put the back case down on a table in front of you with the bottom of the phone close to you.
Put the key guard's tabs into the corresponding tabs on the bottom of the rear casing.
While the key guard's tabs are in the rear casing, put the rear casing's tabs into the bottom of the front casing.
To join the 3 pieces together, push the front and rear casing together so that the clips on the front casing lock into the holes on the rear casing.
Slide the antenna guard on.
Locate the holes that connect the keypad guard to the rear casing.
Find a thin and sturdy screwdriver.
Use the screwdriver to push the rods away from each other until they click into a locked position.
