Motorola California Mobile Phone Motherboard Replacement
Выберете то, что вам нужно
  1. Motorola California Mobile Phone Motherboard Replacement, Motorola California Mobile Phone Teardown: шаг 1, изображение 1 из 1
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Motherboard Replacement: шаг 2, изображение 1 из 1
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Motorola California Mobile Phone Motherboard Replacement: шаг 3, изображение 1 из 1
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
    • Remove the key guard from the rear casing by taking it out of its position.
  4. Motorola California Mobile Phone Motherboard Replacement: шаг 4, изображение 1 из 1
    • Locate and unplug the black component of the antenna from the motherboard.
    • Under the black component should be a blue component. Unscrew this component in order to free the antenna.
  5. Motorola California Mobile Phone Motherboard Replacement: шаг 5, изображение 1 из 1
    • Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
  6. Motorola California Mobile Phone Motherboard Replacement: шаг 6, изображение 1 из 1
    • Lift the motherboard out of its location in the front casing.
    • Do this slowly and gently so that none of the motherboard's components are damaged.
  7. Motorola California Mobile Phone Motherboard Replacement, Motherboard: шаг 7, изображение 1 из 1
    • With your new motherboard, hold the LCD side of the motherboard face down. Align the four clips on the front casing with the four notches on the motherboard.
    • While doing so, insert the LCD into the compartment in the front casing.
  8. Motorola California Mobile Phone Motherboard Replacement: шаг 8, изображение 1 из 1
    • Press firmly on the motherboard until it is snug inside the casing.
Заключение
Еще один человек закончил это руководство.
Andrew Lam
Участник с: 04/17/12
35 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 9-46, Regan Spring 2012 Участник Cal Poly, Team 9-46, Regan Spring 2012
CPSU-REGAN-S12S9G46
5 членов
Автор 8 руководств
Один комментарий
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 13
За последние 30 дней: 22
За всё время: 2,855
