Введение
This guide explains how to replace a damaged or broken camera on the Motorola Cliq. The camera is very fragile, so take care getting it out.
Инструменты
Запчасти
Детали не указаны.
Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery.
Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
Turn the phone over and slide out the keyboard.
Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard.
The rear casing and the rest of the phone should now be completely separated.
Insert a 1.5mm flat head screw in the slit in between the camera housing and the bottom of the camera.
Lightly pry upwards and the camera should come loose from the housing.
Carefully grab the sides of the camera with your fingers and remove the camera.
2 участников успешно повторили данное руководство.
