Введение
The screen is an essential component to all phones. There could be various instances when the screen of your phone begins to malfunction. The following guide will take you step by step on how to install a new screen on your Motorola Defy XT.
Инструменты
Запчасти
Детали не указаны.
Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
Once wedged in the opening, slide the opening tool sideways around the sides of the phone. Remove the back cover and set it aside.
Insert the opening tool between the battery and the battery holder and wedge the battery out.
Open the plastic cover with your finger, exposing the SD card.
Use the opening tool to grab the edge of the SD card and pull it straight out.
Use the Torx T4 torque driver to remove the six 5mm screws on the back case.
Six 3 mm coarse thread screws.
Wedge the plastic opening tool between the plastic layer and the shiny front cover.
Slide the screen out and disconnect the ribbon cable connecting the display to the logic board by pulling straight outward.
2 участников успешно повторили данное руководство.
