Motorola Droid MAXX 2 Rear Camera Replacement
Выберете то, что вам нужно
  1. Motorola Droid MAXX 2 Rear Camera Replacement, Battery: шаг 1, изображение 1 из 1
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Motorola Droid MAXX 2 Rear Camera Replacement: шаг 2, изображение 1 из 1
    • Pull the sim card tray up out of the phone
  3. Motorola Droid MAXX 2 Rear Camera Replacement: шаг 3, изображение 1 из 2 Motorola Droid MAXX 2 Rear Camera Replacement: шаг 3, изображение 2 из 2
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Motorola Droid MAXX 2 Rear Camera Replacement: шаг 4, изображение 1 из 1
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Motorola Droid MAXX 2 Rear Camera Replacement: шаг 5, изображение 1 из 1
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Motorola Droid MAXX 2 Rear Camera Replacement: шаг 6, изображение 1 из 3 Motorola Droid MAXX 2 Rear Camera Replacement: шаг 6, изображение 2 из 3 Motorola Droid MAXX 2 Rear Camera Replacement: шаг 6, изображение 3 из 3
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Motorola Droid MAXX 2 Rear Camera Replacement: шаг 7, изображение 1 из 1
    • Remove the disconnected battery from the phone.
  8. Motorola Droid MAXX 2 Rear Camera Replacement, Rear Camera: шаг 8, изображение 1 из 1
    • Peel up orange adhesive that covers the ZIF connector.
  9. Motorola Droid MAXX 2 Rear Camera Replacement: шаг 9, изображение 1 из 1
    • Use a spudger to lift up the black tab on the ZIF connector.
    • Remove the camera.
Заключение
Burke Seggerman
Участник с: 03/18/18
704 Репутация
Автор 5 руководств
Команда
Baylor, Team S3-G4, Williams Spring 2018 Участник Baylor, Team S3-G4, Williams Spring 2018
BU-WILLIAMS-S18S3G4
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 299
