Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The loudspeaker is responsible for the sound produced by your Droid Mini. When your speaker malfunctions or the sound is distorted, it is probably time to replace the loudspeaker.
Запчасти
Детали не указаны.
  1. Pull out the volume keys using the plastic opening tool. Pull out the volume keys using the plastic opening tool.
    • Pull out the volume keys using the plastic opening tool.
  2. Use the plastic opening tool to gently pry off the back case. Make sure to go around the entire perimeter of the case. Use the plastic opening tool to gently pry off the back case. Make sure to go around the entire perimeter of the case.
    • Use the plastic opening tool to gently pry off the back case. Make sure to go around the entire perimeter of the case.
  3. Use the T5 screw head to unscrew the 9 silver screws from the housing frame. Carefully separate the housing frame from the motherboard.
    • Use the T5 screw head to unscrew the 9 silver screws from the housing frame.
    • Carefully separate the housing frame from the motherboard.
  4. Use the tweezers to gently push the loudspeaker out of the housing frame. Use the tweezers to gently push the loudspeaker out of the housing frame.
    • Use the tweezers to gently push the loudspeaker out of the housing frame.
Заключение
3 участников успешно повторили данное руководство.
Arielle
Участник с: 08.10.2014
619 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 9-2, Leahy Fall 2014 Участник USF Tampa, Team 9-2, Leahy Fall 2014
USFT-LEAHY-F14S9G2
3 членов
Автор 5 руководств
Один комментарий
Does this work with a tx1080
kaziemann123 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 16
За всё время: 2,264
