Motorola Droid Pro Keyboard Replacement
Выберете то, что вам нужно
  1. Motorola Droid Pro Keyboard Replacement, SD Card/SIM Card PCB Board: шаг 1, изображение 1 из 2 Motorola Droid Pro Keyboard Replacement, SD Card/SIM Card PCB Board: шаг 1, изображение 2 из 2
    • Remove the back cover and battery by using the thumb tabs.
  2. Motorola Droid Pro Keyboard Replacement: шаг 2, изображение 1 из 1
    • Unscrew the 8 back panel screws using the T4 Torx screwdriver.
  3. Motorola Droid Pro Keyboard Replacement: шаг 3, изображение 1 из 1
    • Use a spudger to open the phone along the sides between the back panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use a little force to unlock them.
    • Go around on all sides then pull the back panel off.
  4. Motorola Droid Pro Keyboard Replacement: шаг 4, изображение 1 из 2 Motorola Droid Pro Keyboard Replacement: шаг 4, изображение 2 из 2
    • Gently lift the SD & SIM card board (PCB) as shown in the following pictures.
    • This will expose the ribbon cable attached to the board and another ribbon cable for the mother board. Remove them both using the spudger.
    • Once the small one is removed the small board can be pulled off.
  5. Motorola Droid Pro Keyboard Replacement, Screen: шаг 5, изображение 1 из 1
    • Unscrew the 6 screws using the T5 Torx screwdriver.
  6. Motorola Droid Pro Keyboard Replacement: шаг 6, изображение 1 из 1
    • Unlock the ribbon cable and then you can pull the screen out.
    • When replacing screen make sure you lock the ribbon cable back in place.
  7. Motorola Droid Pro Keyboard Replacement, Keyboard: шаг 7, изображение 1 из 1
    • Pop out key board using a spudger on the marked points.
    • The keyboard is locked in place, but can pop in and out. You may need to use a little force to get it out.
    • Once out you can pop the new keyboard in the opposite way you took it out.
Заключение
Peter Cakounes
Участник с: 10/21/14
19 Репутация
Автор 4 руководств
Команда
UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014 Участник UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G8
4 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 166
