Введение
Before continuing through the replacement process make sure you power down your devices and work in a clean area free of dirt. Also use a static band so you don't damage your device.
Выберете то, что вам нужно
Remove the back cover and battery by using the thumb tabs.
Use a spudger to open the phone along the sides between the back panel and the chrome trim.
Go around on all sides then pull the back panel off.
Gently lift the SD & SIM card board (PCB) as shown in the following pictures.
This will expose the ribbon cable attached to the board and another ribbon cable for the mother board. Remove them both using the spudger.
Once the small one is removed the small board can be pulled off.
Pop out key board using a spudger on the marked points.
Once out you can pop the new keyboard in the opposite way you took it out.
