Введение
Before you begin, make sure you power down your device and work in a clean area. Also, wear a static band to prevent damage to your device.
Выберете то, что вам нужно
Remove the back cover using the thumb tab located on the bottom of the phone.
Using a T4 Torx driver, remove the eight 4 mm back panel screws.
Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
Use your plastic opening tool to disconnect the two ribbon cables at the top of the phone.
Disconnect the 2nd keyboard connector from the motherboard and remove it from its side holders.
Remove the camera's rubber seal by pulling it off. It is not connected to anything.
To remove the motherboard, pull it to the side. The camera that is connected to the motherboard does not pull straight up and out from its holder.
3 участников успешно повторили данное руководство.
