Введение
Before continuing make sure you power down your device and work in a clean area. Also wear a static band to prevent damages to your device.
Выберете то, что вам нужно
Remove the back cover using the thumb tab located on the bottom of the phone.
Using a T4 Torx driver, remove the eight 4 mm back panel screws.
Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
2 участников успешно повторили данное руководство.
Один комментарий
Does the replacement board have to be from the same phone or does any sim board work from any phone as long as it's 3g
