Motorola Droid RAZR HD Front Panel Replacement
Выберете то, что вам нужно
  1. Motorola Droid RAZR HD Front Panel Replacement, Front Panel Assembly: шаг 1, изображение 1 из 1
    • Power off the device before disassembly to avoid damage or harm from electrical surges.
    • Remove the two 4.5mm screws in the bottom left and right corners of the device using a T4 Torx Screwdriver.
  2. Motorola Droid RAZR HD Front Panel Replacement: шаг 2, изображение 1 из 1
    • Holding the device in your hand, push the screen towards the top of the phone until it disconnects from the base of the phone.
  3. Motorola Droid RAZR HD Front Panel Replacement: шаг 3, изображение 1 из 1
    • Use a plastic opening tool to lift the screen from the phone.
    • Do not try to completely detach the screen; cables are still connected to the device and can be damaged.
  4. Motorola Droid RAZR HD Front Panel Replacement: шаг 4, изображение 1 из 2 Motorola Droid RAZR HD Front Panel Replacement: шаг 4, изображение 2 из 2
    • Use tweezers to remove the yellow tape covering the lcd/digitizer cable connector.
    • Carefully lift up the black locking tab to release the lcd/digitizer cable.
    • The cable connector is located on the bottom right section of the phone.
  5. Motorola Droid RAZR HD Front Panel Replacement: шаг 5, изображение 1 из 1
    • Lift up the screen further to reveal another cable at the top of the device connecting the motherboard to the screen.
    • This connector is located on the top right section of the phone.
    • Use tweezers to lift the black bar on top of the ZIF connector.
    • Pull the ribbon cable out of the connector with tweezers.
    • Now that there are no cables connecting the screen to the motherboard, remove the screen.
  6. Motorola Droid RAZR HD Front Panel Replacement, Front Panel: шаг 6, изображение 1 из 2 Motorola Droid RAZR HD Front Panel Replacement, Front Panel: шаг 6, изображение 2 из 2
    • Remove the two 2.0mm T4 Torx screws near the top of the screen.
    • Remove the metal plate protecting the front camera and ear speaker with tweezers.
  7. Motorola Droid RAZR HD Front Panel Replacement: шаг 7, изображение 1 из 2 Motorola Droid RAZR HD Front Panel Replacement: шаг 7, изображение 2 из 2
    • Using a plastic openining tool, lift up the front camera and ear speaker assembly.
    • Remove the assembly with tweezers.
Заключение
2 участников успешно повторили данное руководство.
Brendan Baronia
Участник с: 04/14/15
678 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 4-4, Maness Spring 2015 Участник Cal Poly, Team 4-4, Maness Spring 2015
CPSU-MANESS-S15S4G4
5 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 1,614
