Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the two 4.5mm screws in the bottom left and right corners of the device using a T4 Torx Screwdriver.
Holding the device in your hand, push the screen towards the top of the phone until it disconnects from the base of the phone.
Use a plastic opening tool to lift the screen from the phone.
Use tweezers to remove the yellow tape covering the lcd/digitizer cable connector.
Carefully lift up the black locking tab to release the lcd/digitizer cable.
Lift up the screen further to reveal another cable at the top of the device connecting the motherboard to the screen.
Use tweezers to lift the black bar on top of the ZIF connector.
Pull the ribbon cable out of the connector with tweezers.
Now that there are no cables connecting the screen to the motherboard, remove the screen.
Remove the two 3.5mm Torx T4 screws securing the rear facing camera.
Using tweezers, remove the metal shield protecting the rear facing camera.
Use a plastic opening tool to lift up the rear camera.
Use tweezers to lift and unlock the black bar on top of the rear camera's ZIF connector.
Pull the camera out of the connector.
2 участников успешно повторили данное руководство.
