Motorola Droid RAZR M Battery Door Glass Lens Replacement
Выберете то, что вам нужно
  1. Motorola Droid RAZR M Battery Door Glass Lens Replacement, Battery Door Glass Lens: шаг 1, изображение 1 из 1
    • Shattered!
  2. Motorola Droid RAZR M Battery Door Glass Lens Replacement: шаг 2, изображение 1 из 1
    • Glass won't just pop off. It is held by a very sticky tape. Carefully scraping the tape with the glass pieces off and vacuum the area after to prevent a clean surface.
    • Be aware of jumping tiny glass pieces during process. Protect your eyes and area around you. They can get stuck in skin too.
  3. Motorola Droid RAZR M Battery Door Glass Lens Replacement: шаг 3, изображение 1 из 1
    • To replace the part you first need to attach the sticky tape. It comes in the correct outlines. Take the inner parts out to keep those areas free (Camera, Flash, Loudspeaker and a hole).
    • Before you take the film off practice the attaching. You will have it hard to reposition after its attached. Same goes with the lens itself, practice before the tape film is off. Once you feel safe to go, peel the film off and go for it!
  4. Motorola Droid RAZR M Battery Door Glass Lens Replacement: шаг 4, изображение 1 из 1
    • Done :-)
Финишная черта
4 участников успешно повторили данное руководство.
Alex R
Участник с: 09/27/13
215 Репутация
1 руководство автора
3 Комментариев
This is not a razr maxx !!!!
Fausto Lebron - Ответить
This isn't a Razr Maxx. The back doesn't have glass on a razr maxx.
Alex Tucker - Ответить
This is Droid razr m . not maxx
Qais Afridi - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 13
За всё время: 7,390
