Введение
Use this guide to replace the glass on the rear of your Motorola Droid RAZR M.
Выберете то, что вам нужно
Glass won't just pop off. It is held by a very sticky tape. Carefully scraping the tape with the glass pieces off and vacuum the area after to prevent a clean surface.
Be aware of jumping tiny glass pieces during process. Protect your eyes and area around you. They can get stuck in skin too.
To replace the part you first need to attach the sticky tape. It comes in the correct outlines. Take the inner parts out to keep those areas free (Camera, Flash, Loudspeaker and a hole).
Before you take the film off practice the attaching. You will have it hard to reposition after its attached. Same goes with the lens itself, practice before the tape film is off. Once you feel safe to go, peel the film off and go for it!
4 участников успешно повторили данное руководство.
3 Комментариев
This is not a razr maxx !!!!
This isn't a Razr Maxx. The back doesn't have glass on a razr maxx.
This is Droid razr m . not maxx
