Motorola Droid RAZR Maxx Back Cover Replacement
Выберете то, что вам нужно
  1. Motorola Droid RAZR Maxx Back Cover Replacement, Taking off the Back Cover: шаг 1, изображение 1 из 2 Motorola Droid RAZR Maxx Back Cover Replacement, Taking off the Back Cover: шаг 1, изображение 2 из 2
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola Droid RAZR Maxx Back Cover Replacement: шаг 2, изображение 1 из 2 Motorola Droid RAZR Maxx Back Cover Replacement: шаг 2, изображение 2 из 2
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • Continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola Droid RAZR Maxx Back Cover Replacement: шаг 3, изображение 1 из 3 Motorola Droid RAZR Maxx Back Cover Replacement: шаг 3, изображение 2 из 3 Motorola Droid RAZR Maxx Back Cover Replacement: шаг 3, изображение 3 из 3
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
Заключение
4 человек успешно провели ремонт по этому руководству.
sean crocker
Участник с: 10/08/14
341 Репутация
1 руководство автора
Команда
USF Tampa, Team 14-6, Leahy Fall 2014 Участник USF Tampa, Team 14-6, Leahy Fall 2014
USFT-LEAHY-F14S14G6
4 членов
Автор 10 руководств
2 Комментарии к руководству
Ok so I have the cover off of the back of my Droid Razr Maxx HD? But where is it that I can purchase the new back cover? I figured you guys would have at least a hyper link to somewhere I could buy it? Instead of just having instructions on how to remove the backing? Thanks Very Respectfully, Joey K
sailorjt1985 - Ответить
I have same problem. Need new back cover.
TheShellex - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 9
За всё время: 2,910
