Motorola Droid Turbo Dual LED Flash Board Replacement
Выберете то, что вам нужно
  1. Motorola Droid Turbo Dual LED Flash Board Replacement, Rear Case: шаг 1, изображение 1 из 1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
    This di not work; I had to use a blow dryer.
    Caroline Downie - Ответить
  2. Motorola Droid Turbo Dual LED Flash Board Replacement: шаг 2, изображение 1 из 2 Motorola Droid Turbo Dual LED Flash Board Replacement: шаг 2, изображение 2 из 2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
    I had to go around the case, starting on the non-button side, around the top and then the other side. This, unfortunately, pulled on the rear case, pressed the power button and turned the device back on. I would suggest starting on the button side and going around.
    Ryan Helinski - Ответить
  3. Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: шаг 3, изображение 1 из 2 Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: шаг 3, изображение 2 из 2
    • Use a Jimmy to separate the dual LED flash board from the rear case.
    • The board is secured with some light adhesive, so some force may be required.
    What I meant to say was great job! Also I have a question about the adhesive pads holding the flash on. Shouldn't they be replaced as well? My flash wasn't working so I took the back off and cleaned the contacts and put it back together. It worked fine for a couple of days and went back to only blinking. The pads seem to be letting the flash part move with the chop motion to activate the flashlight,
    Rongwey - Ответить
Заключение
Еще один человек закончил это руководство.
Geoff Wacker
Участник с: 09/30/13
89 895 Репутация
Автор 89 руководств
Один комментарий
Gostaria se possível alguem tenha o manual de serviço do Moto maxx XT 1225 ou 1254. Porf favor , ddani8260@gmail.com
Daniel Gomes - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 959
