Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Use this guide to replace the headphone jack on your Droid Turbo.
  1. Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Use a plastic opening tool to pry the rear case off of the rest of the device. Remove the rear case.
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  4. Remove the midframe bezel.
    • Remove the midframe bezel.
  5. Remove the four Torx T5 screws securing the midframe plate.
    • Remove the four Torx T5 screws securing the midframe plate.
  6. Remove the midframe.
    • Remove the midframe.
  7. Insert the pointed end of a spudger into the headphone jack, and gently pry the jack up and away from the midframe. Insert the pointed end of a spudger into the headphone jack, and gently pry the jack up and away from the midframe.
    • Insert the pointed end of a spudger into the headphone jack, and gently pry the jack up and away from the midframe.
Заключение
3 участников успешно повторили данное руководство.
Geoff Wacker
Участник с: 30.09.2013
81 043 Репутация
Автор 89 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 3,058
