Введение
Use this guide to replace the rear-facing camera on your Motorola Droid Turbo.
Выберете то, что вам нужно
Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
Use a plastic opening tool to pry the rear case off of the rest of the device.
Remove the rear case.
Remove the four Torx T5 screws securing the lower antenna board to the motherboard.
Use the flat end of a spudger to flip up the retaining flap on the display ZIF connector.
Pull the display ribbon cable free of the connector.
Use the flat end of a spudger to flip up the black retaining flap on the front-facing camera ZIF connector.
Use the flat end of a spudger to flip up the tan retaining flap on the rear-facing camera ZIF connector.
3 участников успешно повторили данное руководство.
