Введение
If you are experiencing having a problem with your LCD or digitizer, follow this installation guide. This is a challenging tutorial, that requires a complete deconstruction of the Droid X. Proceed with caution.
  1. Locate the power button at the top of the phone.  Depress power button for 2 seconds until a menu appears. Locate the power button at the top of the phone.  Depress power button for 2 seconds until a menu appears.
    • Locate the power button at the top of the phone. Depress power button for 2 seconds until a menu appears.
  2. Once the menu appears, select the "power off" option.  Wait until the phone is completely off. Once the menu appears, select the "power off" option.  Wait until the phone is completely off.
    • Once the menu appears, select the "power off" option. Wait until the phone is completely off.
  3. Place thumb on the back cover, and push down towards the bottom of the device.  Once the cover releases, pull it away from the phone and set it aside. Place thumb on the back cover, and push down towards the bottom of the device.  Once the cover releases, pull it away from the phone and set it aside.
    • Place thumb on the back cover, and push down towards the bottom of the device. Once the cover releases, pull it away from the phone and set it aside.
  4. Find the yellow pull tab located in the upper left corner.  Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case. Find the yellow pull tab located in the upper left corner.  Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
    • Find the yellow pull tab located in the upper left corner. Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
  5. The battery has been successfully removed.
    • The battery has been successfully removed.
  6. Remove the micro SD card from its connector.
    • Remove the micro SD card from its connector.
  7. Locate the seam between the back case and the end cover on the top edge of the phone. Use the plastic opening tool to detach the two clips by wedging the tool into the right side of the seam and moving right to left.  Once the cover comes off set it aside Use the plastic opening tool to detach the two clips by wedging the tool into the right side of the seam and moving right to left.  Once the cover comes off set it aside
    • Locate the seam between the back case and the end cover on the top edge of the phone.
    • Use the plastic opening tool to detach the two clips by wedging the tool into the right side of the seam and moving right to left. Once the cover comes off set it aside
  8. Repeat step 2 on the bottom cover. Repeat step 2 on the bottom cover. Repeat step 2 on the bottom cover.
    • Repeat step 2 on the bottom cover.
  9. Use a T5 Torx screwdriver to remove the screws in each corner of the phone. The screws are very small so make sure not to lose them. The screws are very small so make sure not to lose them.
    • Use a T5 Torx screwdriver to remove the screws in each corner of the phone.
    • The screws are very small so make sure not to lose them.
  10. Flip the phone over and locate the screw on the middle of the left side. Unscrew it using the T5 Torx screwdriver and set it aside. Flip the phone over and locate the screw on the middle of the left side. Unscrew it using the T5 Torx screwdriver and set it aside.
    • Flip the phone over and locate the screw on the middle of the left side. Unscrew it using the T5 Torx screwdriver and set it aside.
  11. Identify the screw located in the bottom right corner of the battery case.  Remove the screw with a T5 (or in some cases T6) torx screwdriver and set it aside. Identify the screw located in the bottom right corner of the battery case.  Remove the screw with a T5 (or in some cases T6) torx screwdriver and set it aside.
    • Identify the screw located in the bottom right corner of the battery case. Remove the screw with a T5 (or in some cases T6) torx screwdriver and set it aside.
  12. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  13. Locate the seam along the right edge of the phone.  Use the prying tool to disconnect the two clips along the edge. Locate the seam along the right edge of the phone.  Use the prying tool to disconnect the two clips along the edge.
    • Locate the seam along the right edge of the phone. Use the prying tool to disconnect the two clips along the edge.
  14. Locate the two clips on the inside of the case and use the spudger tool to detach them from the case.  To detach each clip, use the sharp end to press the small, black plastic in the center of the clip. Locate the two clips on the inside of the case and use the spudger tool to detach them from the case.  To detach each clip, use the sharp end to press the small, black plastic in the center of the clip. Locate the two clips on the inside of the case and use the spudger tool to detach them from the case.  To detach each clip, use the sharp end to press the small, black plastic in the center of the clip.
    • Locate the two clips on the inside of the case and use the spudger tool to detach them from the case. To detach each clip, use the sharp end to press the small, black plastic in the center of the clip.
  15. After the clips are detached, remove the back case and set it aside. After the clips are detached, remove the back case and set it aside.
    • After the clips are detached, remove the back case and set it aside.
  16. Remove the screws along both sides of the motherboard using a T3 Torx screwdriver. On some phones this may require a #1 Phillips Screw Driver.
    • Remove the screws along both sides of the motherboard using a T3 Torx screwdriver. On some phones this may require a #1 Phillips Screw Driver.
  17. Carefully remove the white connecting wire from the motherboard using tweezers. Use caution, this wire is delicate.
    • Carefully remove the white connecting wire from the motherboard using tweezers.
    • Use caution, this wire is delicate.
  18. Scrape away the electrical tape that covers the LCD and digitizer cable using the spudger tool or a fingernail. Scrape away the electrical tape that covers the LCD and digitizer cable using the spudger tool or a fingernail.
    • Scrape away the electrical tape that covers the LCD and digitizer cable using the spudger tool or a fingernail.
  19. Use the spudger tool to pop the Digitizer cable off of the motherboard.
    • Use the spudger tool to pop the Digitizer cable off of the motherboard.
  20. Carefully flip the small white connector up and away from the motherboard.
    • Carefully flip the small white connector up and away from the motherboard.
  21. Gently pull the flat gold cable out from the connector.
    • Gently pull the flat gold cable out from the connector.
  22. Carefully lift the motherboard and camera module up. Do not remove it from the phone!
    • Carefully lift the motherboard and camera module up. Do not remove it from the phone!
  23. Using the spudger tool, pop the black cable connector off of the motherboard.
    • Using the spudger tool, pop the black cable connector off of the motherboard.
  24. It is to safe remove the motherboard from the phone.
    • It is to safe remove the motherboard from the phone.
  25. Using tweezers, peel back the black safety information sticker. Using tweezers, peel back the black safety information sticker.
    • Using tweezers, peel back the black safety information sticker.
  26. Using tweezers, peel the orange and black cable away from the device, stopping before reaching the electrical tape at the near the edge of the screen.
    • Using tweezers, peel the orange and black cable away from the device, stopping before reaching the electrical tape at the near the edge of the screen.
  27. Peel black the black electrical tape located near the bottom of the device.
    • Peel black the black electrical tape located near the bottom of the device.
  28. Flip up the cable connector and pull out the small flat cable.
    • Flip up the cable connector and pull out the small flat cable.
  29. Carefully pull the long orange cable away from the device. Carefully pull the long orange cable away from the device.
    • Carefully pull the long orange cable away from the device.
  30. Unscrew the screw at the base of the screen using the T4 torx screwdriver . Unscrew the screw at the base of the screen using the T4 torx screwdriver .
    • Unscrew the screw at the base of the screen using the T4 torx screwdriver .
  31. Peel back the orange and gold connector from the left side of the phone.
    • Peel back the orange and gold connector from the left side of the phone.
  32. Carefully separate the metal plate from the LCD and front housing.
    • Carefully separate the metal plate from the LCD and front housing.
  33. Lift the LCD out of the front housing. Lift the LCD out of the front housing.
    • Lift the LCD out of the front housing.
  34. Remove all dust and smudges from the LCD and front housing before installing the screen.
    • Remove all dust and smudges from the LCD and front housing before installing the screen.
Заключение
17 участников успешно повторили данное руководство.
Sam Johnston
Участник с: 03.10.2012
519 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 18-40, Regan Fall 2012 Member of Cal Poly, Team 18-40, Regan Fall 2012
CPSU-REGAN-F12S18G40
3 членов
Автор 5 руководств
How much does it cost to get what I need and where can I get it
jacob - Ответить
Thank you. This is very helpful.
Albert Einstine - Ответить
Добавить комментарий
Просмотр статистики:
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
За всё время: 14,122
