Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Locate the power button at the top of the phone. Depress power button for 2 seconds until a menu appears.
Once the menu appears, select the "power off" option. Wait until the phone is completely off.
Place thumb on the back cover, and push down towards the bottom of the device. Once the cover releases, pull it away from the phone and set it aside.
Find the yellow pull tab located in the upper left corner. Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
Locate the seam between the back case and the end cover on the top edge of the phone.
Use the plastic opening tool to detach the two clips by wedging the tool into the right side of the seam and moving right to left. Once the cover comes off set it aside
Use a T5 Torx screwdriver to remove the screws in each corner of the phone.
Flip the phone over and locate the screw on the middle of the left side. Unscrew it using the T5 Torx screwdriver and set it aside.
Identify the screw located in the bottom right corner of the battery case. Remove the screw with a T5 (or in some cases T6) torx screwdriver and set it aside.
Locate the seam along the right edge of the phone. Use the prying tool to disconnect the two clips along the edge.
Locate the two clips on the inside of the case and use the spudger tool to detach them from the case. To detach each clip, use the sharp end to press the small, black plastic in the center of the clip.
After the clips are detached, remove the back case and set it aside.
Remove the screws along both sides of the motherboard using a T3 Torx screwdriver. On some phones this may require a #1 Phillips Screw Driver.
Carefully remove the white connecting wire from the motherboard using tweezers.
Scrape away the electrical tape that covers the LCD and digitizer cable using the spudger tool or a fingernail.
Use the spudger tool to pop the Digitizer cable off of the motherboard.
Carefully flip the small white connector up and away from the motherboard.
Carefully lift the motherboard and camera module up. Do not remove it from the phone!
Using the spudger tool, pop the black cable connector off of the motherboard.
Using tweezers, peel back the black safety information sticker.
Using tweezers, peel the orange and black cable away from the device, stopping before reaching the electrical tape at the near the edge of the screen.
Peel black the black electrical tape located near the bottom of the device.
Flip up the cable connector and pull out the small flat cable.
Unscrew the screw at the base of the screen using the T4 torx screwdriver .
Peel back the orange and gold connector from the left side of the phone.
Carefully separate the metal plate from the LCD and front housing.
18 участников успешно повторили данное руководство.
2 Комментариев
Thank you. This is very helpful.
