Введение
When the E815 becomes unresponsive, removing and replacing the battery is often the first and best solution.
To replace the battery, you are going to:
- Remove back cover
- Remove Battery
- Replace Battery
Locate the battery removal slot.
Use your finger to pull the battery out from the top.
Remove the battery.
2 участников успешно повторили данное руководство.
