Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Инструмент, используемый на этом этапе:Spudger$3.99-
Begin by removing the trim piece.
Using your fingers or The Spudger, get underneath the trim. Start by applying enough force to pry the trim off.
Remove the face plate.
Once you have removed the trim you will see 4 gold screws at the corners of the phone. Using a T5 Torx Screwdriver, remove the screws.
Alternatively use a spudger to carefully lift up the glass from the metal support, there is no need to remove the screws. The glass is much cheaper and easier to find then the glass/metal
Gently, using The Spudger towards the edge or the top of the phone and lift the face plate off.
Be careful during this step, the touch-sensitive keys and chip board (which is green) may remain attached to the face plate. Gently hold the chip board down as you lift the face plate.
Once you have removed the broken face plate, replace it with your the new one.
Follow all of these steps in reverse order to reassemble the phone.
