Введение
In this guide you will be taught how to take apart the plastic shell of your parent unit and remove the speaker. Some soldering will be required to fully replace the speaker.
Выберете то, что вам нужно
Using the Phillips #1 screwdriver, remove the battery cover screw.
Remove the battery cover from its hinges and set aside.
Lift the battery from its slot.
Using precision tweezers, grip the connector plug.
Wiggle the connector plug and pull up to remove the connecting wires.
Remove the battery from the unit and set it aside.
Using the Phillips #1 screwdriver, remove the 7mm screw under the battery cover.
Using the blue plastic opening tools, begin prying open the corners and disconnecting the seven clasps around the edges of the parent unit.
Grip the speaker's metal clasp with tweezers and then pull on the clasp to remove.
