Введение
This guide will show users how to take apart the camera housing in order to replace the speaker.
Выберете то, что вам нужно
Remove two 5 mm Phillips #1 screws from the bottom of the camera stand.
Remove the two 5 mm Phillips #1 screws attached to the black plastic under the casing.
Remove the Phillips #1 screws on the back of the device.
Use a nylon spudger to remove the casing. This will separate the frontside of the camera from the backside.
Now locate the brackets by the speaker on the frontside of the camera and use the metal spudger to carefully disconnect from casing.
Continue to use the metal spudger to carefully disconnect the remaining brackets from the casing.
Using the soldering iron, desolder the speaker wires that are attached to the circuit board.
After desoldering the speaker wires, remove the wires from the circuit board.
