Введение
The MC55 series device is intended for industrial and commercial use. Thus, parts like the charging port can become damaged by extended use and wear. This guide will help the user to break down and replace the charging port of the MC5590.
Выберете то, что вам нужно
Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
Use a plastic opening tool to remove the keyboard cover by prying up on its perimeter.
Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
Pull the ribbon cable out of the socket.
Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
Remove the keyboard from the device.
Remove the three Phillips #00 screws from the motherboard:
Two 3mm screws.
One 1mm screw.
Remove the the 3mm Phillips #00 screws from the flex cable cover and antenna.
Remove the antenna.
Remove the flex cable cover.
Flip open the motherboard and the LCD screen.
Open the LCD connector and remove the cable.
Pull the LCD Screen and its metal bracket apart.
Remove the antenna connector (red box).
This is a snap-on connector, which can be removed by applying a gentle pull straight up from the motherboard.
Remove the 2 screws (3 mm long) at the bottom of the motherboard using a PH00-bit screwdriver.
Disconnect the charging port from the rest of the device.
