Введение
Use this guide to replace the motherboard in your device.
Выберете то, что вам нужно
Use your finger or the tip of a spudger to compress the pin securing the watch band.
With the pin compressed, remove the watch band.
Insert an opening tool to into the small notch next to the microphone hole.
Slide the opening tool around the perimeter of the trim ring while prying up slightly to slice through the adhesive securing the ring to the watch.
Remove the trim ring.
Use an opening tool to slowly pry the button trim ring straight up.
Use a small pin spanner to unscrew the button.
Remove the button.
While holding the outer case steady, twist the inner watch assembly clockwise until it stops.
Hold the outer watch case steady and push against the bottom of the inner assembly to remove the inner assembly from the frame.
Use a fingernail or opening tool to pry the plastic lower assembly away from the display assembly.
Use tweezers to remove the small rubber strip between the battery and the display ZIF connector.
Use the flat end of a spudger to gently pry the battery out of the case.
Use the point of a spudger to pry up the battery connector and disconnect the battery.
Detach the copper ribbon connecting the motherboard and the display.
Use the spudger to separate the motherboard casing from the rear housing.
Еще один человек закончил это руководство.
