Введение
This panel should be removed to get to all of the watch's insides. It is extremely fragile, so use caution when removing it.
Инструменты
Запчасти
Детали не указаны.
Set the watch face down on a flat surface.
Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
Follow the instructions here to remove the back cover without force by using some needles in the right places:
Then continue with step 5. Or don't use needles and just continue with the next steps.
Gently slide the blue opening pick between the rear cover and the metal casing.
Work your way entirely around the rear cover.
Once the adhesive has been successfully loosened, gently pull the rear cover off.
9 участников успешно повторили данное руководство.
Один комментарий
How does this *rear cover replacement* count as "no parts required"?
