Motorola Moto E 2nd Generation Earpiece Speaker Replacement
Выберете то, что вам нужно
  1. Motorola Moto E 2nd Generation Earpiece Speaker Replacement, Display Assembly: шаг 1, изображение 1 из 1
    • Turn off the device before beginning your repair.
    • Using a heat gun, carefully apply heat around the edges of the display to soften the glue. Heat should be applied to the point where the phone isn't too hot to touch, but close enough.
  2. Motorola Moto E 2nd Generation Earpiece Speaker Replacement: шаг 2, изображение 1 из 3 Motorola Moto E 2nd Generation Earpiece Speaker Replacement: шаг 2, изображение 2 из 3 Motorola Moto E 2nd Generation Earpiece Speaker Replacement: шаг 2, изображение 3 из 3
    • Using the small plastic opening tool, pry and slide all the way around the phone while carefully lifting up on the display.
    • The screen is secured by two-sided tape located on the edge.
    Do not lift the screen too far or you may tear the LCD connection flexi. Check next images to see where it is, bottom and opposing side to the buttons
    MW Wilson - Ответить
  3. Motorola Moto E 2nd Generation Earpiece Speaker Replacement: шаг 3, изображение 1 из 3 Motorola Moto E 2nd Generation Earpiece Speaker Replacement: шаг 3, изображение 2 из 3 Motorola Moto E 2nd Generation Earpiece Speaker Replacement: шаг 3, изображение 3 из 3
    • Once display is fully unglued from the frame, carefully lift it up and locate the display connector.
    • Using the same small plastic tool, carefully remove the yellow tape off the connector.
    • Now carefully undo the black connector lock by lifting it up in the direction of the red arrow.
    • Do not pry on the gray part of the connector.
    • Lastly slide the display cable off the connector. It should easily slide off, if not make sure the black lock is fully unlatched.
    Very well put together. Worked fine for me.
    A guitar pick will work as well as the plastic tool, but it might be a little harder to work with.
    Jon Gregory - Ответить
  4. Motorola Moto E 2nd Generation Earpiece Speaker Replacement, Earpiece Speaker: шаг 4, изображение 1 из 3 Motorola Moto E 2nd Generation Earpiece Speaker Replacement, Earpiece Speaker: шаг 4, изображение 2 из 3 Motorola Moto E 2nd Generation Earpiece Speaker Replacement, Earpiece Speaker: шаг 4, изображение 3 из 3
    • Now that the display is out, remove the aluminum shield off the motherboard.
    • Unscrew the single 4mm screw located on the top using a T4 Torx bit.
    • After screw is out, gently remove the aluminum shield off the motherboard.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
  5. Motorola Moto E 2nd Generation Earpiece Speaker Replacement: шаг 5, изображение 1 из 2 Motorola Moto E 2nd Generation Earpiece Speaker Replacement: шаг 5, изображение 2 из 2
    • Using the metal spudger tool, very carefully remove the speaker by first gently prying up on the right side and then the bottom.
    • The ear piece is held by double sided tape and clips to the motherboard so be very careful.
    You can see a plastic clip on the right, so I understand the justification for prying on the right first. However, when I tried prying on the right, it separated the two halves of the speaker, ruining it. There was also a pad of foam, double sided tape under mine.
    Paul K - Ответить
    If you see in the other side the plastic clip is smaller , I was able to release this clip (the left side one) and in the bottom part of the speaker you can see a little gap when i put my pointy metal spudger and help the speaker slowging going up, it fells a little hard to push because of the magnet in it.
    Jose Carlos -
    I found I did not need to remove the speaker. I was able to (just barely) reach the screw behind it without removing it. After removing all of the other screws, I loosened that one a little bit at a time while gently prying the motherboard out of the case. Eventually it was all the way removed and I was able to take out the motherboard.
    David - Ответить
    Great tip about not removing the speaker. I, too, managed to remove that screw behind the speaker. I didn’t even need to pry out the motherboard while doing it.
    Keith R -
    Is the T4 Torx bit the one with the hole in it?
    Lynette - Ответить
    I think you may be referring to a security torx bit. These screws just need standard torx bits, although a security one should work too. Lookup torx on Wikipedia and impress/bore your friends for evermore.
    Keith R -
    Sir need track diagram for this………… speakers track might be cut….
    Harsh Kadam - Ответить
Заключение
10 участников успешно повторили данное руководство.
Andre Romualdo
Участник с: 02/08/16
3 765 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 12-3, Eyestone Spring 2016 Участник USF Tampa, Team 12-3, Eyestone Spring 2016
USFT-EYESTONE-S16S12G3
3 членов
Автор 14 руководств
3 Комментариев
Olá André. Gostaria de saber se aquela peça a direita do earpiece speaker é outro falante.
Questiono pq o meu Moto E2 apresenta um som meio chiado nas ligações, porém no viva voz ou reproduzindo mídia o som é limpo, normal.
Obrigado.
Caio Andrade - Ответить
I almost bought another phone but I read it was common for these phones to have ear piece issues like mine does.
Thank You so much for the information it was perfect, I just ordered the ear piece.
sarjpr - Ответить
Ciao Andre e grazie davvero!
enricolag - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 10,535
