Motorola Moto E 2nd Generation Rear Facing Camera Replacement
Выберете то, что вам нужно
  1. Motorola Moto E 2nd Generation Rear Facing Camera Replacement, Display Assembly: шаг 1, изображение 1 из 1
    • Turn off the device before beginning your repair.
    • Using a heat gun, carefully apply heat around the edges of the display to soften the glue. Heat should be applied to the point where the phone isn't too hot to touch, but close enough.
  2. Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 2, изображение 1 из 3 Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 2, изображение 2 из 3 Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 2, изображение 3 из 3
    • Using the small plastic opening tool, pry and slide all the way around the phone while carefully lifting up on the display.
    • The screen is secured by two-sided tape located on the edge.
  3. Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 3, изображение 1 из 3 Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 3, изображение 2 из 3 Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 3, изображение 3 из 3
    • Once display is fully unglued from the frame, carefully lift it up and locate the display connector.
    • Using the same small plastic tool, carefully remove the yellow tape off the connector.
    • Now carefully undo the black connector lock by lifting it up in the direction of the red arrow.
    • Do not pry on the gray part of the connector.
    • Lastly slide the display cable off the connector. It should easily slide off, if not make sure the black lock is fully unlatched.
  4. Motorola Moto E 2nd Generation Rear Facing Camera Replacement, Earpiece Speaker: шаг 4, изображение 1 из 3 Motorola Moto E 2nd Generation Rear Facing Camera Replacement, Earpiece Speaker: шаг 4, изображение 2 из 3 Motorola Moto E 2nd Generation Rear Facing Camera Replacement, Earpiece Speaker: шаг 4, изображение 3 из 3
    • Now that the display is out, remove the aluminum shield off the motherboard.
    • Unscrew the single 4mm screw located on the top using a T4 Torx bit.
    • After screw is out, gently remove the aluminum shield off the motherboard.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
  5. Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 5, изображение 1 из 2 Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 5, изображение 2 из 2
    • Using the metal spudger tool, very carefully remove the speaker by first gently prying up on the right side and then the bottom.
    • The ear piece is held by double sided tape and clips to the motherboard so be very careful.
  6. Motorola Moto E 2nd Generation Rear Facing Camera Replacement, Motherboard: шаг 6, изображение 1 из 1
    • Unscrew the remaining 16- 4mm screws using a T4 Torx bit.
    • Using a magnet board is recommended as the screws are small and can be easily misplaced.
  7. Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 7, изображение 1 из 3 Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 7, изображение 2 из 3 Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 7, изображение 3 из 3
    • Next remove the plastic C-shaped black plastic frame.
    • Using the metal spudger tool, gently pull up the right corner as indicated and work your way around until it's off the motherboard.
  8. Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 8, изображение 1 из 2 Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 8, изображение 2 из 2
    • Gently lift up the battery cable connector, it should come out very easy.
  9. Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 9, изображение 1 из 3 Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 9, изображение 2 из 3 Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 9, изображение 3 из 3
    • After the battery cable is disconnected from the motherboard, use the metal spudger tool and carefully insert it in the small opening by the speaker and pry the motherboard up enough to fit your finger in between the motherboard and the phone frame.
    • Now just pull the motherboard starting from the top to bottom off the phone case.
  10. Motorola Moto E 2nd Generation Rear Facing Camera Replacement, Rear Facing Camera: шаг 10, изображение 1 из 2 Motorola Moto E 2nd Generation Rear Facing Camera Replacement, Rear Facing Camera: шаг 10, изображение 2 из 2
    • Using a spudger (ignore the pictured screwdriver), pry up the metal square frame on each side until it comes off.
  11. Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 11, изображение 1 из 2 Motorola Moto E 2nd Generation Rear Facing Camera Replacement: шаг 11, изображение 2 из 2
    • Once the metal square frame is out, use the same tool to pry up the camera by gently pulling on each side until it comes off
Заключение
4 участников успешно повторили данное руководство.
Andre Romualdo
Участник с: 02/08/16
3 765 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 12-3, Eyestone Spring 2016 Участник USF Tampa, Team 12-3, Eyestone Spring 2016
USFT-EYESTONE-S16S12G3
3 членов
Автор 14 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,339
