Введение
You will need to remove the outer back plastic cover and the battery connection in order to access the motherboard and camera parts to do the replacement.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Выберете то, что вам нужно
To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
Gently pull up on the red and black power cable to lift the connector out of the motherboard.
Move the battery and cover away from the motherboard.
Use the same plastic opening tool to pry the camera assembly off.
Use the plastic opening tool on all four sides of the camera several times until it starts to come loose.
Pull the camera assembly out.
Place the new camera assembly into the connector and press gently.
2 участников успешно повторили данное руководство.
