Motorola Moto E4 Rear Facing Camera Replacement
Выберете то, что вам нужно
  1. Motorola Moto E4 Rear Facing Camera Replacement, Remove the rear cover: шаг 1, изображение 1 из 2 Motorola Moto E4 Rear Facing Camera Replacement, Remove the rear cover: шаг 1, изображение 2 из 2
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Rear Facing Camera Replacement, Remove the motherboard cover: шаг 2, изображение 1 из 2 Motorola Moto E4 Rear Facing Camera Replacement, Remove the motherboard cover: шаг 2, изображение 2 из 2
    • The battery is shown inserted in the Moto E4, but it should be removed before performing the following step.
    • Remove all nine 4 mm Phillips screws from the top plastic cover.
  3. Motorola Moto E4 Rear Facing Camera Replacement: шаг 3, изображение 1 из 2 Motorola Moto E4 Rear Facing Camera Replacement: шаг 3, изображение 2 из 2
    • Gently pry up the plastic cover using a plastic opening tool.
    • Start by inserting the tool under the cover's right edge, as indicated by the first picture.
    • Pry up, and continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
  4. Motorola Moto E4 Rear Facing Camera Replacement: шаг 4, изображение 1 из 3 Motorola Moto E4 Rear Facing Camera Replacement: шаг 4, изображение 2 из 3 Motorola Moto E4 Rear Facing Camera Replacement: шаг 4, изображение 3 из 3
    • This step can be skipped if you are only removing the front-facing camera. For all other repairs, continue as follows.
    • Disconnect the rear-facing camera by prying straight up on the connector on its right side.
    • Remove the rear-facing camera from the Moto E4.
Заключение
Nate Tjepkema
Участник с: 01/24/19
1 236 Репутация
Автор 7 руководств
Команда
Cal Poly, Team S2-G4, White Winter 2019 Участник Cal Poly, Team S2-G4, White Winter 2019
CPSU-WHITE-W19S2G4
4 членов
Автор 22 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 10
За всё время: 698
