Введение
The inner circuit board covers inside the Motorola Moto E6 Play phone protect the two circuit boards, including the motherboard. They need to be removed in order to access several different components of the phone, including both cameras, the fingerprint scanner, and the battery.
Инструменты
Запчасти
Детали не указаны.
Run the halberd spudger along the edges of the device. The back cover should easily pop off.
To remove the cover on the motherboard, remove the 10 silver 3.90 mm Phillips screws attaching the cover to the board using the Phillips #0 screwdriver.
With the angled tweezers, remove the black cover to reveal the motherboard underneath.
The bottom plastic piece covering the daughterboard can be seen by peeling back the tape covering the bottom section of the phone below the battery.
To remove the cover, unscrew the six black 3.45 mm Phillips screws holding the cover in place using the Phillips #0 screwdriver.
