Введение
The front camera of the Motorola Moto E6 Play phone is a 5MP, f2.2, 1.12 µm pixel camera. If you are experiencing the ‘Camera Busy’ error, click here for troubleshooting solutions. However, if you are experiencing other issues with the front camera, or the troubleshooting guides do not solve the problem, you may need to replace the camera.
Запчасти
Детали не указаны.
Run the halberd spudger along the edges of the device. The back cover should easily pop off.
To remove the cover on the motherboard, remove the 10 silver 3.90 mm Phillips screws attaching the cover to the board using the Phillips #0 screwdriver.
With the angled tweezers, remove the black cover to reveal the motherboard underneath.
The bottom plastic piece covering the daughterboard can be seen by peeling back the tape covering the bottom section of the phone below the battery.
To remove the cover, unscrew the six black 3.45 mm Phillips screws holding the cover in place using the Phillips #0 screwdriver.
Use the angled tweezers to pry off the metal head of the connecting piece from the main motherboard assembly.
Using the angled tweezers, detach the two connectors from the motherboard by pulling the metallic heads up and away from the phone.
Disconnect the rod connected to the motherboard using the angled tweezers.
Finally, remove the motherboard.
Flip the motherboard over to see the back. (The side that does not have the 'a' mark on it.)
Using the angled tweezers, lift the tab at the bottom of the camera piece and remove the front facing camera from the circuit board.
