Motorola Moto G 1st Generation Front Camera Replacement
Выберете то, что вам нужно
  1. Careful: steps 1-3 are sourced from a guide that's marked as in-progress.
    Motorola Moto G 1st Generation Front Camera Replacement, Rear Panel: шаг 1, изображение 1 из 3 Motorola Moto G 1st Generation Front Camera Replacement, Rear Panel: шаг 1, изображение 2 из 3 Motorola Moto G 1st Generation Front Camera Replacement, Rear Panel: шаг 1, изображение 3 из 3
    • Before you start following any of the steps of this guide, completely turn the device off.
    • Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
  2. Motorola Moto G 1st Generation Front Camera Replacement, Removing the Screws: шаг 2, изображение 1 из 1
    • Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
  3. Motorola Moto G 1st Generation Front Camera Replacement, Removing the Battery Cover: шаг 3, изображение 1 из 2 Motorola Moto G 1st Generation Front Camera Replacement, Removing the Battery Cover: шаг 3, изображение 2 из 2
    • Use a plastic opening tool to remove the protective cover.
    • Carefully work the plastic tool around all the edges of the phone.
    • The protective cover holds the Volume and the Home buttons which might fall off the assembly when the cover is removed.
  4. Motorola Moto G 1st Generation Front Camera Replacement, Disconnecting the Front Camera: шаг 4, изображение 1 из 2 Motorola Moto G 1st Generation Front Camera Replacement, Disconnecting the Front Camera: шаг 4, изображение 2 из 2
    • Use the Pry tool to disconnect the Front Camera, found in the upper right corner, from the motherboard.
    • You want to pry up the black tab that locks it in place. It may be under a protective sticker.
    • Though the battery is removed in our second photo, it is not required for removing the front camera.
  5. Motorola Moto G 1st Generation Front Camera Replacement, Removing the Front Camera: шаг 5, изображение 1 из 2 Motorola Moto G 1st Generation Front Camera Replacement, Removing the Front Camera: шаг 5, изображение 2 из 2
    • Remove the camera from the phone by using the tweezers.
    • To reassemble, follow the steps in reverse.
Заключение
4 участников успешно повторили данное руководство.
Radostin Lobodov
Участник с: 10/16/14
2 904 Репутация
Автор 6 руководств
Команда
UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014 Участник UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G7
3 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 1,260
