Motorola Moto G 1st Generation Headphone Jack Replacement
Выберете то, что вам нужно
  1. Careful: steps 1-3 are sourced from a guide that's marked as in-progress.
    Motorola Moto G 1st Generation Headphone Jack Replacement, Rear Panel: шаг 1, изображение 1 из 3 Motorola Moto G 1st Generation Headphone Jack Replacement, Rear Panel: шаг 1, изображение 2 из 3 Motorola Moto G 1st Generation Headphone Jack Replacement, Rear Panel: шаг 1, изображение 3 из 3
    • Before you start following any of the steps of this guide, completely turn the device off.
    • Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
  2. Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Screws: шаг 2, изображение 1 из 1
    • Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
  3. Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Battery Cover: шаг 3, изображение 1 из 2 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Battery Cover: шаг 3, изображение 2 из 2
    • Use a plastic opening tool to remove the protective cover.
    • Carefully work the plastic tool around all the edges of the phone.
    • The protective cover holds the Volume and the Home buttons which might fall off the assembly when the cover is removed.
  4. Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Headphone Jack: шаг 4, изображение 1 из 3 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Headphone Jack: шаг 4, изображение 2 из 3 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Headphone Jack: шаг 4, изображение 3 из 3
    • Use the plastic opening tool to remove the Headphone Jack from the protective cover and replace it.
Заключение
Radostin Lobodov
Участник с: 10/16/14
2 904 Репутация
Автор 6 руководств
Команда
UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014 Участник UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G7
3 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 2,365
