Введение
This guide will teach you how to replace the motherboard in your Moto G, in the event that it is malfunctioning. It may take a while, since the battery and SD/SIM card reader must be removed first, but all you will need are a T5 Torx screwdriver and a plastic opening tool.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Выберете то, что вам нужно
Starting at the USB port on the bottom, remove the rear cover by prying it off with your finger.
Work your way down the sides to avoid cracking the rear cover.
Remove the eight 4.2 mm screws at the top and bottom of the phone using a T5 Torx screwdriver.
Using the same screwdriver, remove the six 3.2 mm screws on the sides.
Remove the next layer of the phone by prying it off with your fingers.
Using a plastic opening tool or tweezers, disconnect the SIM/SD card reader at the top of the phone.
Disconnect the battery connector by prying it off of the motherboard.
Disconnect the vibration motor by prying its connector off of the motherboard.
Using a plastic opening tool, carefully pry off the entire SIM/SD card reader component.
Peel off the two black stickers on the right side of the battery using your fingers.
Remove the battery by pulling the right side of it upwards.
Using a T5 Torx screwdriver, unscrew the three 2.2 mm screws holding the motherboard in place.
30 участников успешно повторили данное руководство.
4 Комментариев
What about Android, it comes already flashed on a new motherboard or I need to flash it myself?
Where can i buy mother board for moto g 2nd gen lte. Any idea?
