Выберете то, что вам нужно
Release SIM & SD card reader assembly connector and battery connector. Get loosen the vibrator.
Remove the battery with card reader assembly together at first. And then separate them.The battery flex is stuck on the back of the card reader assembly.
20 участников успешно повторили данное руководство.
9 Комментариев
Hola, donde se puede comprar el reemplazo para el slot Sim-card del Moto G 2014 segunda generación?
Ebay, Aliexpress, Amazon, etc.
Example : http://www.amazon.com/MOTOROLA-2070mAh-L...
Just look at the reference on your removed battery, and order the same.
Xavier -
Battery Problem battery fast charge & fast low
