Введение
This is a guide to replace the fingerprint sensor on the Moto G Power (2020). Follow these simple steps for a successful repair! If you encounter other issues, refer to our troubleshooting page.
Before you begin, download the Rescue and Smart Assistant app. This will allow you to back up your device and determine if your problem is software or hardware-related.
Place a suction cup on the back of the device.
Then open up the back of the device by sliding the opening pick into both sides of the phone.
Put pressure on the fingerprint sensor with your finger to detach it from the back panel.
Carefully use the spudger to lift the sensor cable, disconnecting the fingerprint sensor from the motherboard.
