Введение
This guide will walk you through replacing the LCD on a 2021 Moto G Power. This guide will use a frameless LCD replacement part. If your replacement LCD already comes with the midframe attached, simply follow along until that point.
Выберете то, что вам нужно
Heat up the back of the G Power with a heat gun or iOpener
Once the adhesive has softened, insert an opening pick and slide it carefully around the perimeter of the phone to open it.
Unplug the battery connector with a spudger
Apply 100% isopropyl alcohol to the edges of the battery. Wait one minute to let the alcohol loosen the adhesive.
Pry the battery up carefully. Remove & set aside.
heat lcd(can use decent amount of heat to remove)
insert opening tool and slide around the perimeter of the LCD to slice the adhesive
clean off old adhesive, then apply new glue(either double sided sticky tape or adhesive)
put plastic covers on and screw them in
remove most of the old adhesive
apply either double sided sticky tape or adhesive glue and put the plastic back cover on
if it is not sitting well try to heat it up and press it in a phone press or in between heavy books
You did it!
You did it!
2 участников успешно повторили данное руководство.
