Введение
Full Device Name: Motorola Moto Stylus 4G (2023)
Model Number: XT2317
Alternate Name: Moto Stylus 4G (2023)
Objective: This guide aims to provide step-by-step instructions for replacing the battery in the Motorola Moto Stylus 4G (2023).
About the Battery: This device sports a model PG50 lithium ion battery (XT 2317) with a 5000 mAh capacity.
Device Symptoms: If the device begins to show a low battery life, longer charge times, or overheats, then use this guide to replace the battery.
Выберете то, что вам нужно
Insert an opening pick under the edge of the case and slide it around the edges.
Separate the back panel from the rest of the phone.
Use the opening pick along the edges to separate the camera lens glass from the board.
Disconnect the four cables by inserting the opening pick beneath the edge of each.
