Введение
The ringer speaker is an essential component responsible for producing audible alerts such as incoming calls, notifications, and alarms. If you're experiencing issues like no sound or poor audio quality from your device's ringer, replacing the ringer speaker can resolve these problems and restore clear and audible alerts.
Guide Objective: This guide provides detailed step-by-step instructions on how to safely and effectively replace the ringer speaker in your Moto G Stylus 4G (2023).
Before You Begin:
- Safety Precautions: Power off your device completely and disconnect any power sources before starting the replacement process. Work in a well-lit and clean environment to avoid losing small parts or causing accidental damage.
- Backup Data: Although this replacement does not involve data manipulation, it's a good practice to back up your device's data as a precautionary measure.
Device Symptoms: Common symptoms indicating the need for ringer speaker replacement include:
- No sound or low volume from the ringer
- Distorted or crackling audio during alerts
- Inconsistent or intermittent ringer functionality
Выберете то, что вам нужно
Insert an opening pick under the edge of the case and slide it around the edges.
Separate the back panel from the rest of the phone.
Use the opening pick along the edges to separate the camera lens glass from the board.
Disconnect the four cables by inserting the opening pick beneath the edge of each.
