Введение
If you have a cracked or damaged lens then it's best to replace it so your photos are crystal clear again. Follow this guide to do it yourself!
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Выберете то, что вам нужно
Place your thumb in the indent located at bottom left corner of the back cover.
The cover will pop up and begin to lift
Continue to slide your fingers up the sides to remove the back cover
Slide a pair of tweezers under and around the lens to loosen it.
Pulls the lens towards you to remove.
6 участников успешно повторили данное руководство.
