Введение
Use this guide to:
- Replace or remove the battery
- As a starting point for any other repair/replacement needed on the phone, since it's hazardous to keep the battery in
If your battery is swollen, take appropriate precautions.
Выберете то, что вам нужно
Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
Place the plastic opening tool into the notch located at the bottom of the battery compartment, and lift upwards. If you don’t have an opening tool, use your finger nails.
Remove battery from your phone.
6 участников успешно повторили данное руководство.
