Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Use this guide to replace the midframe of your Motorola Moto G4 Play if damaged, or to access the internal components. Consider using a magnetic mat to organize the screws that will be removed from the device.
Запчасти
Детали не указаны.
  1. Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails. Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails. Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
    • Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
  2. Lift the case by the nearest corner to the divot and remove it from the phone. Lift the case by the nearest corner to the divot and remove it from the phone. Lift the case by the nearest corner to the divot and remove it from the phone.
    • Lift the case by the nearest corner to the divot and remove it from the phone.
  3. Place the plastic opening tool into the notch located at the bottom of the battery compartment, and lift upwards. If you don’t have an opening tool, use your finger nails. Remove battery from your phone. Remove battery from your phone.
    • Place the plastic opening tool into the notch located at the bottom of the battery compartment, and lift upwards. If you don’t have an opening tool, use your finger nails.
    • Remove battery from your phone.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Remove any SIM card and/or memory card present using your hand. Remove any SIM card and/or memory card present using your hand. Remove any SIM card and/or memory card present using your hand.
    • Remove any SIM card and/or memory card present using your hand.
  6. Remove the small silicon cover at the bottom right of the camera using tweezers. Remove the small silicon cover at the bottom right of the camera using tweezers.
    • Remove the small silicon cover at the bottom right of the camera using tweezers.
  7. Remove the sixteen (16) 3mm Phillips PH000 screws securing the midframe.
    • Remove the sixteen (16) 3mm Phillips PH000 screws securing the midframe.
    • Some phones have two shorter screws, one on each side of the battery (double marked with orange circles at left). If your device has these shorter screws, make sure they go back in their original holes.
  8. Remove the back panel assembly with your hands. Remove the back panel assembly with your hands. Remove the back panel assembly with your hands.
    • Remove the back panel assembly with your hands.
Заключение
Еще один человек закончил это руководство.
Paola Rossi
Участник с: 15.02.2018
436 Репутация
Автор 3 руководств
Команда
USF Tampa, Team S17-G4, Boczar Spring 2018 Участник USF Tampa, Team S17-G4, Boczar Spring 2018
USFT-BOCZAR-S18S17G4
4 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 18
За всё время: 680
