Введение
Use this guide to replace a dead or low battery.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
If your battery is swollen, take appropriate precautions.
Выберете то, что вам нужно
If possible, drain the battery before disassembly. When the battery is charged, there's an increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
Apply a suction cup to the bottom edge of the rear glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Insert an opening pick into the gap you created under the rear glass.
Slide the pick all along the bottom edge of the phone to slice through the adhesive securing the rear glass.
Slide the pick along the right edge of the rear glass to separate the adhesive underneath.
Slide the pick all along the top edge of the phone to slice through the adhesive securing the rear glass.
Slide a pick along the left edge of the phone to slice through the rear glass adhesive.
Инструмент, используемый на этом этапе:Tesa 61395 Tape$5.99
If the glass remains stuck, re-heat and slice the adhesive repeatedly as needed.
Lift the rear glass carefully, making sure it's fully separated from any adhesive.
Remove the rear glass.
Use a pair of tweezers to carefully peel up the black tape covering the battery.
Remove the tape.
Use a Phillips driver to remove seventeen screws securing the plastic cover:
Eleven grey 3 mm-long screws
Five black 2.5 mm-long screws
One silver 3.5 mm-long screw
Insert the pointed end of a spudger into the notch at the top left edge of the plastic cover.
Pry up with the spudger to lift the upper edge of the cover and release the clips holding the cover down.
Remove the plastic cover.
Use the pointed end of a spudger to pry up the battery connector and disconnect it.
Prepare an iOpener and apply it to the right half of the screen for at least two minutes, in order to soften the battery adhesive underneath. Reheat and reapply the iOpener as needed.
Use an opening pick to steadily pry the battery up, starting from the outer edge of the battery.
Remove the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto G6 Answers community for help.
35 участников успешно повторили данное руководство.
8 Комментариев
This is a beautifully done tutorial. I have written over 100 service manuals, and have seen few procedures described better than this.
One of the best instructions that I have used and the Ifixit tool kit was perfect and the price for everything was very good.
One of the best tutorials I have followed. Even this 73 year old was able to easily follow and finish the project without difficulty. Thank you, I now have a new battery in my cell phone. Happy customer.
Moto G6 charging problem
thank you for writing this up. I could follow your steps without any issue. The telephone is glued together really well, it took me many attempts to take off the back cover glass and also the battery. Just keep (re)heating the phone and slowly work with the picks, it will come off eventually.
